######## Shopstat mall nicht nehmen ????
Die aus den QF10 mal versuchen mit anpassung wen nötig so ist die fett kan anders sein bei 1und1
ZitatAlles anzeigen# .htaccess for commerce:SEO URL
# angepasst von Sebastian Schramm, Daniel Siekiera, Andreas Kausch
# Blog Integration - Daniel SiekieraAddDefaultCharSet utf-8
# Wenn Sie 1und1 benutzen, setzen Sie die nächsten beiden Zeilen aktiv (Einschalten PHP5)
#AddType x-mapp-php5 .php
#AddHandler x-mapp-php5 .php# Expire headers 31536000 Sekunden = 1 Jahr
<IfModule mod_expires.c>
ExpiresActive On
ExpiresDefault "access plus 31536000 seconds"
ExpiresByType image/x-icon "access plus 31536000 seconds"
ExpiresByType image/gif "access plus 31536000 seconds"
ExpiresByType image/jpg "access plus 31536000 seconds"
ExpiresByType image/jpeg "access plus 31536000 seconds"
ExpiresByType image/png "access plus 31536000 seconds"
ExpiresByType text/css "access plus 31536000 seconds"
ExpiresByType text/javascript "access plus 31536000 seconds"
ExpiresByType application/javascript "access plus 31536000 seconds"
ExpiresByType application/x-javascript "access plus 31536000 seconds"
ExpiresByType image/ico "access plus 31536000 seconds"
ExpiresByType text/html "access plus 31536000 seconds"
</IfModule># BEGIN Cache-Control Headers
<ifmodule mod_headers.c>
<filesmatch "\\.(ico|jpe?g|png|gif|swf)$">
Header set Cache-Control "max-age=31536000, public"
</filesmatch>
<filesmatch "\\.(css)$">
</filesmatch>
<filesmatch "\\.(js)$">
</filesmatch>
<filesmatch "\\.(ico)$">
</filesmatch>
</ifmodule><ifmodule mod_deflate.c>
<FilesMatch "\\.(js|css|html|htm|php|xml|jpg|jpeg|png|gif)$">
SetOutputFilter DEFLATE
</FilesMatch>
</ifmodule>
<ifmodule mod_gzip.c>
mod_gzip_on Yes
mod_gzip_dechunk Yes
mod_gzip_minimum_file_size 500
mod_gzip_maximum_file_size 500000
mod_gzip_maximum_inmem_size 60000
mod_gzip_min_http 1000
mod_gzip_handle_methods GET POST
mod_gzip_item_exclude reqheader "User-agent: Mozilla/4.0[678]"
mod_gzip_item_include file \.(html?|txt|css|js|php|pl)$
mod_gzip_item_include handler ^cgi-script$
mod_gzip_item_include mime ^text/.*
mod_gzip_item_include mime ^application/x-javascript.*
mod_gzip_item_include mime ^text/html$
mod_gzip_item_include mime ^text/css$
mod_gzip_item_include mime ^text/js$
mod_gzip_item_include mime ^image/jpeg$
mod_gzip_item_include mime ^image/png$
mod_gzip_item_include mime ^image/gif$
mod_gzip_item_include mime ^text/plain$
mod_gzip_item_include mime ^httpd/unix-directory$
mod_gzip_item_exclude mime ^image/.*
mod_gzip_item_exclude rspheader ^Content-Encoding:.*gzip.*
</ifmodule># Turn ETags Off
Header unset ETag
</ifmodule>
FileETag None# Zusatzparameter PHP
#php_value max_execution_time 60000
#php_value memory_limit 160M
#php_value arg_separator.output &# Dateiauflisting unterbinden
Options -Indexes# Kommentieren Sie diese Zeile aus, wenn Sie einen Fehler 500 (Internal Server Error) erhalten
#Options +FollowSymlinks<IfModule mod_rewrite.c>
RewriteEngine On
#Sicherheit mal ganz weg lassen zum test
## Begin - Rewrite rules to block out some common exploits.
# If you experience problems on your site block out the operations listed below
# Block out any script trying to base64_encode data within the URL.
## RewriteCond %{QUERY_STRING} base64_encode[^(]*\([^)]*\) [OR]
# Block out any script that includes a <script> tag in URL.
## RewriteCond %{QUERY_STRING} (<|%3C)([^s]*s)+cript.*(>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL.
## RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR]
# Block out any script trying to modify a _REQUEST variable via URL.
## RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2})
# Return 403 Forbidden header and show the content of the root homepage
## RewriteRule .* index.php [F]
# Port Scanner
## RewriteCond %{HTTP_USER_AGENT} ^w00tw00t.at.ISC.SANS.DFind
## RewriteRule ^.*$ 403.php [L]
## End - Rewrite rules to block out some common exploits.
Options +SymLinksIfOwnerMatch
# Umleitung auf Adresse mit www, wenn www fehlt und nicht Subdomain und nicht localhost und nicht ssl.webpack.de
RewriteCond %{HTTP:X-Forwarded-Server} !^ssl\.webpack\.de$ [NC]
RewriteCond %{HTTP:X-Forwarded-Server} !^sslsites\.de$ [NC]
RewriteCond %{HTTP_HOST} !^www\..* [NC]
RewriteCond %{HTTP_HOST} !^.*\..*\..* [NC]
RewriteCond %{HTTP_HOST} !^localhost(.*)$ [NC]
RewriteRule ^(.*) http://www.%{HTTP_HOST}/$1 [R=301,L]# immer auf den root verweisen, damit die Startseite (/index.php) nicht zweimal vorkommt
# die folgenden beiden Zeilen auskommentieren wenn Sie eine index.html nutzen wollen
RewriteCond %{THE_REQUEST} ^[A-Z]{3,9}\ /index\.(html?|php)\ HTTP/
RewriteRule ^index\.(html?|php)$ http://%%7bhttp_host%7d/ [R=301,L]# Editieren Sie die untenstehende Zeile wenn ihr Shop in einem Unterordner läuft.
# Aber auch wenn Sie einen Fehler 500 (Internal Server Error) bekommen.
# Beispiel: Ist ihr Shop im Verzeichnis http://www.domain.de/shop ändern Sie die Zeile wie folgt: "RewriteBase /shop/"
#RewriteBase /RewriteCond %{REQUEST_FILENAME} -f [OR]
RewriteCond %{REQUEST_FILENAME} -dRewriteRule ^(.+) - [PT,L]
RewriteCond %{REQUEST_URI} !(.*)/$
RewriteCond %{REQUEST_URI} !\..+$
RewriteCond %{REQUEST_URI} !/$
RewriteRule (.*) http://%%7bhttp_host%7d/%241/ [R=301,L]RewriteRule ^(.*)(.+)404.php$ 404.php [qsappend,L]
RewriteRule ^(.*)tag/(.*([a-zA-Z0-9]))/$ taglisting.php?tag=$1$2 [qsappend,L]
#RewriteRule ^(.*)keywords/(.*([a-zA-Z0-9]))$ advanced_search_result.php?keywords=$1$2 [qsappend,L]
#RewriteRule ^(.*)manufacturer-(.*[0-9])/(.*([a-zA-Z0-9]))$ index.php?manufacturers_id=$2 [qsappend,L]
RewriteRule ^(.*)review-(.*[0-9])/(.*([a-zA-Z0-9]))\.html$ product_reviews_info.php?reviews_id=$2 [qsappend,L]#RewriteRule ^(.*)(.+)\.html(.*)$ commerce_seo_url.php?linkurl=$1$2$3 [qsappend,L]
RewriteCond %{REQUEST_FILENAME} !\.html$ [OR]
RewriteCond %{REQUEST_FILENAME} !\.php$ [OR]
RewriteRule ^(.*)$ commerce_seo_url.php?linkurl=$1 [qsappend,L]
</IfModule>
